om603 Pump 6mm elements
Mercedes-Benz conversations only
ducos
Viesti Kirjoittaja ducos »
Hello mercedes friends.
I have swapped 6mm elements into my pump, it works fine but not real power increase before i adjust the max fuel for each cylinder. I have tried minimal adjustments, but i screwed up. is there any way to adjust this diy without the bosch machine? Anything more than stock is a good improvement for me since our track is only 2nd gear max... no room for 3gear..
