OM.606 Turbo engine into W123?
Mercedes-Benz conversations only
dalek
Viesti Kirjoittaja dalek »
Not trying to interrupt the conversation, I have a question: which manual transmissions are you using over there with those engines?
Forced_Induction
Re:
Viesti Kirjoittaja Forced_Induction »
Alastair kirjoitti: --And, YES you DO delete posts that you dont agree with
Alastair, please try to act like an adult. Only then will you actually understand what you're pretending to talk about.
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
dalek
Re: OM.606 Turbo engine into W123?
I guess it would be too much to ask to go back to the topic...
eric78
Re:
Viesti Kirjoittaja eric78 »
Forced_Induction kirjoitti:
Can you tell how much originally om605 gives torgue at 4500, 5000, or 6000rpm?
None since they don't naturally revv that high.
Um, the NA om602 revs to 5,500, so a 605 should rev past 5000 easy.
Forced_Induction
Re: Re:
eric78 kirjoitti:
Forced_Induction kirjoitti:Um, the NA om602 revs to 5,500, so a 605 should rev past 5000 easy.
Incorrect. They can revv that high unloaded, under a load the governor cuts fuel before 5000rpm.
1982 300D
dalek
I know I am not as knowledgeable as you, so could you please explain to the unwashed masses what does a fuel pump governor has to do with the physical limitations of an engine?
Forced_Induction
Re:
Alastair kirjoitti:Why is it you have been banned from more Fora than anyone else I know?
I have a low tolerance for ignorant people, and those ignorant people feel that exposing their ignorance is "offensive". Winmutt is one such perfect example.
1982 300D
Forced_Induction
dalek kirjoitti:I know I am not as knowledgeable as you, so could you please explain to the unwashed masses what does a fuel pump governor has to do with the physical limitations of an engine?
Everything. The injection pump is a mechanical device, it has limitations that are impractical to completely eliminate. If you were to set the governor to limit the engine RPM to the maximum safe speed then the RPM it could revv to with a load would be limited. Since the engine can't revv higher than the loaded limit with a load, the potential of damaging the engine from excessive mechanical stress of overspeed is averted. This is known in the engineering world as, "a compromise".
Go revv a completely computerized engine and you'll find the loaded and unloaded maximum RPMs are the same.
1982 300D
dalek
Forced_Induction kirjoitti:Everything. The injection pump is a mechanical device, it has limitations that are impractical to completely eliminate. If you were to set the governor to limit the engine RPM to the maximum safe speed then the RPM it could revv to with a load would be limited. Since the engine can't revv higher than the loaded limit with a load, the potential of damaging the engine from excessive mechanical stress of overspeed is averted. This is known in the engineering world as, "a compromise".
Now, wouldn't it be reasonable to assume the car manufacturer choose those limits not due to the DNE engine specs but to satisfy their operational lifetime goals? If that is the case, those who are willing to sacrifice some longevity to in exchange of gains they seek would seek a different point in the graph. Case in point would be the VW AEB engine delivering 700+ HP.
After all, fuel delivery systems can be changed.
Einar
Viesti Kirjoittaja Einar »
Back to the engine mountings:
I think the mountings from W126 300SDL would be a perfect fit for a 606 in W123, maybe the 300SE could fit too.
Mercedes Benz 300 TD Turbodiesel
123.193 OM617.952
1,2 bar turbopressure
Ford Granada 2.8 Ghia, 180 hp, 5-speed, 3.45:1
Ford Granada 2.0
