As topic, is it able to use the IP from the 10v 250 to make it able to use the 290td engine in a w110 I´m building?
Original the 290td have alot of electrical wich make it hard to connect to an another car, right?
Rebuild the 290TD with mechanical ip
- Forced_Induction
- Viesti:
Re: Rebuild the 290TD with mechanical ip
The 290 is completely computer controlled. I'm pretty sure the mounting is different, though I know one person jerry rigged a W123 300D pump to work.
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
