LIIKENNEMERKKITUNNISTIN !
Re: LIIKENNEMERKKITUNNISTIN !
Keskustelu alla;
Hi,
I confirm, that with my SLA+VIM unlock you will have SLA work in Finland as well (I sold out several items to FI already). You can order no problem.
same module can do some more useful features on your car:
1. remote ACC (automatic comfort opening and closing windows, sunroof and trunk) using ignition key lock/unlock buttons
http://youtu.be/tvSJ-7j8RUI" onclick="window.open(this.href);return false;
2. ECO Off (make ECO function OFF by default)
http://youtu.be/JP1r1lImYPE" onclick="window.open(this.href);return false;
these can be activated later on (after installation) with activation code - let me know if you are interested
you can contact me here over email if you like: http://yadi.sk/d/3FLyKYJzFYPwZ" onclick="window.open(this.href);return false;
Hi again,
1. Video-in-motion as well as internet is included as well (ACC adn ECO of is also possible) - so you will have VIM+SLA and later you will be able to activate
ACC and ECO_Off if you like.
2. No - most probably SLA information will not be shown on COMAND, this depends from MAP and Finland map does not have this feature enabled (this is why SLA does not work) - but you will see it on IC definately
Hi,
car on my video is w212 2009 and IC is B/W - that's why color is BW. You car is 2011 with color IC and for sure all signs will be visible in colour.
Traffic sign priority is highest and you will see it:
- 5 secs at any mode of IC
- permanently if you will enter to SLA mode on IC, in that case last sign will be visible for long period if time (several minutes at least or till next sign)
Hi,
Hi again,
Hi,
W212 E 220 T BlueTec aut. Avant 2015 (facelift)
W205 C220 T BlueTec d aut. Avant 2016
W205 C200 T BlueTEC d aut. Business 2015
W205 C250 T BlueTEC d aut. Avant 2015
S204 C 200 CDI aut. Avant AMG Styling 2008
W204 C200 T CDI aut. Avant 2014
W204 C220 T CDI aut. Avant 2012 AMG Styling Panorama
W204 C220 T CDI aut Avant 2012 AMG Styling
W204 C220 T CDI aut Avant 2011 Panorama
S211 E280 S CDI aut Avant 2008 (Facelift)
S211 E280 S CDI aut Avant 2006 (Facelift)
W203 C270 T CDI aut Avant 2002
W203 C270 T CDI aut Avant 2001
W210 E270 T CDI aut Avant 2000
W210 E290 T TD aut Avant1996
V70 Volvo 2.0 aut 2000
W124 E250 D 1990
W124 E250 D 1990
SLA CAN-filter in action: http://youtu.be/k6fZNIAYQR4" onclick="window.open(this.href);return false;
Thanx ! Hyvin näyttää toimivan sekä mittarissa että navissa.
W124 E250 D 1990
W124 E250 D 1990
Yhden 60-rajoitusmerkin jätti huomioimatta tuolla pätkälläkin.
Ok ! Mutta olet tyytyväinen systeemiin - oletan ?
W124 E250 D 1990
W124 E250 D 1990
No joo. Mielummin näin kuin ilman.
Moottoritiellä ei tunnu löytävän merkkejä. Oliskohan ne Suomessa liian sivussa ja korkealla?
Kyllä se liikennemerkkitieto pysyy kartalla koko ajan, kun on maassa, jossa se toimii oletusten mukaisesti. Saavuin eilen Hampurista kotiin.
Moi ! Olekto vielä tyytyväinen tuohon filtteriin ? Tulin tänään Saksasta uuden (-12) C:n kanssa ja kyllä tuo liikennemerkkitunnistin on hyvä ! Tässä näkyi mittaristossa myös tämän tunnistimen Assistant symboli, mutta Vuosaaressa hävisi mittaristosta
Huomasin myös että Saksassa navin kartoissa oli optip näyttää topograafisena kartat, näytti hyvältä. Laivalta ajaessani huomasin että ei näy täällä - ehkä Suomi karttoja ei ole topografisina, koska en muuttanut asetuksia. Taidan nyt hankkia tuon filtterin vaikka Commandin purkaminen vähän pelottaa.
Sain vireystila - assistantinkin (kahvikuppi mittaristossa) toimimaan n. 800 km yhtäjaksoisen ajamisen jälkeen. Näyttöön tuli teksti että pitäisi pitää tauko ja taisi piippaakin. Testattu siis että toimii
W124 E250 D 1990
W124 E250 D 1990
Joo kyllä se parempi tuolla filtterillä on kuin ilman. En ole käynyt kyseisellä autolla Saksassa asennuksen jälkeen joten en tiedä pysyykö nopeustieto ruudulla enää sen asennuksen jälkeen.
Ja vireystila-avustin kyllä alkaa väkisinkin piipata viimeistään Södertäljen slummeissa. Piippasi taas siellä reilu viikko takaperin, kun tulin Hampurista kotiin.
Hankin itsellekkin tuon SLA modulin. Kyllä mulla tuossa Oulun moottoritiellä ainakin havaitsee rajoitukset. (Rampissa ei havainnut). Sellainen havainto että 40km/h nopeus jää näyttöön siihen asti että tulee uus liikennemerkki joka havaitaan. 60-100km/h näkyy noin 0,5km ja häviää. Tuohon ko sais asetuksen vielä että aina pysyy viimeisin nopeus niin hienoa ois. Kyllä on vaan hyvä lisävaruste.7
Edit: Comandin purku on helppo nakki. https://www.youtube.com/watch?v=tq6Sr6KwtMI" onclick="window.open(this.href);return false;
EDIT2: Onko kukaan tilannut SLA modulin toimittajalta lisätoimintoja tuohon moduuliin? Oliko se että 20 USD laaki esim. Eco mode pois käytöstä? Lampunpesimien manuaali toiminto? Aattelin vaan että jos tilais kimpassa? Luulen että sama ratin nappien funtio tomii kaikille moduuleille..
Tuikutusta Oulun kuppeessa
Ex: S212 250 CDI 4matic -12
Ex: Basuuna PWD -03
Ex: S204 220 CDI Mopf "AMG"
EX: Basuuna PWD -02
EX: W638 110D -97
EX: C30T CDI AMG -05
EX: S203 200 CDI -03
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Mites s212 (6/2011)? Toimi hyvin Saksa/Tanska/Ruotsi, muttei enää Suomessa (Comand ei kyllä myöskään ilmoittanut ettei toimisi). Navin kartat on vuodelta 2012.DBFI kirjoitti:Siis toimii kyllä monissa muissa MB malleissa mutta ei tuossa puheena olleessa 204:ssa.tn62634 kirjoitti:Eihän sellaiset Kekkoslovakiassa toimi. Virossa ja Ruotsissakin toimii, mutta ei täällä. Varusteena on kyllä todella hyvä ja toimiva. Comand ilmoittaa Suomeen tultaessa, että kyseinen varuste ei ole täällä toiminnassa. Valitettavasti.
Vaatiiko tuon filtterin, vai saako toimimaan jotenkin muuten?
Vaatii varmaan filtterin. Näyttääkö inoperative tekstin mittaristossa?tj86430 kirjoitti:Mites s212 (6/2011)? Toimi hyvin Saksa/Tanska/Ruotsi, muttei enää Suomessa (Comand ei kyllä myöskään ilmoittanut ettei toimisi). Navin kartat on vuodelta 2012.DBFI kirjoitti:Siis toimii kyllä monissa muissa MB malleissa mutta ei tuossa puheena olleessa 204:ssa.tn62634 kirjoitti:Eihän sellaiset Kekkoslovakiassa toimi. Virossa ja Ruotsissakin toimii, mutta ei täällä. Varusteena on kyllä todella hyvä ja toimiva. Comand ilmoittaa Suomeen tultaessa, että kyseinen varuste ei ole täällä toiminnassa. Valitettavasti.
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Joo, näytti olevan (ei siis huomauttanut mitään maahan tullessa, mutta valikoista tunnistimen asetukset esiin ottamalla näyttää tuon tekstin)simppa80 kirjoitti:Vaatii varmaan filtterin. Näyttääkö inoperative tekstin mittaristossa?tj86430 kirjoitti:Mites s212 (6/2011)? Toimi hyvin Saksa/Tanska/Ruotsi, muttei enää Suomessa (Comand ei kyllä myöskään ilmoittanut ettei toimisi). Navin kartat on vuodelta 2012.DBFI kirjoitti:Siis toimii kyllä monissa muissa MB malleissa mutta ei tuossa puheena olleessa 204:ssa.tn62634 kirjoitti:Eihän sellaiset Kekkoslovakiassa toimi. Virossa ja Ruotsissakin toimii, mutta ei täällä. Varusteena on kyllä todella hyvä ja toimiva. Comand ilmoittaa Suomeen tultaessa, että kyseinen varuste ei ole täällä toiminnassa. Valitettavasti.
Mulla on yks tollanen uusi/ylimääräinen. 160€.
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Oliko tästä havaintoa että vaikuttaako jotenkin tunnistimen toimintaan niissä maissa, joissa se toimisi ilmankin (siis siihen näkyykö rajoitus koko ajan navissa vai häipyykö vähän ajan päästä, vrt. aiempi keskustelu)?simppa80 kirjoitti:Mulla on yks tollanen uusi/ylimääräinen. 160€.
Tuskin vaikuttaa toimintaan. Comand näyttää varmaan rajoituksen normaalisti niissä maissa joissa se on käytössä. Toisekseen jos vaikuttaa niin pitää 8sek. Luuri alas nappia pohjassa niin moduli on pois käytöstä. Comandiin muistaakseni nopeus jää näkyviin jos se on karttapohjassa. Mittaristossa näkyy aina vain sen hetken, mutta 40km/h ja hitaammat jää näyttöön pysyvästi assistant sivulle.
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Unelmavävy
- Sisäänajossa
Onkohan tähän tullut uusia (kartta)päivityksiä joilla tunnistin toimisi ilman huijausta? Toimiiko tunnistin suomessa w204 suomiautoissa ilman huijausta? Jos toimii niin millä kartta-aineistolla?
s204 C200 CDI BE T A Facelift -11
Saako tätä värkättyä toimimaan W221:ssä, vm 2010? Autossa on Comand APS navigaattori sekä ajoavustin plus paketti.
Mistä saa selville että mikä karttaversio autossa on?
Ei toimi w204 suomiautossa. Ei tule uusilla kartoilla toimimaan. Eikä taida toimia edes modulilla w221.
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
- terasankka
Nostan tälläisen vanhemman viestin, kun en löytänyt haulla vastausta. Toimiikohan tuo liikennemerkkitunnistin Suomessa 2012 mallin W212:ssa?
W212 E350 CDI 4Matic -12
Ei ilman temppuja.terasankka kirjoitti:Nostan tälläisen vanhemman viestin, kun en löytänyt haulla vastausta. Toimiikohan tuo liikennemerkkitunnistin Suomessa 2012 mallin W212:ssa?
- terasankka
OK.. onko pääkaupunkiseudulla joku joka tekee temppuja vaikka korvausta vastaan?
Jos sinne laittaa can-filtterin niin ei sekään ihmeisiin pysty.
En osaa sanoa varmasti toimiiko 2012 mallissa, mutta 2014 ja 2015 mallien autoissa on ainakin tunnistin toiminut moitteettomasti.tj86430 kirjoitti:Ei ilman temppuja.terasankka kirjoitti:Nostan tälläisen vanhemman viestin, kun en löytänyt haulla vastausta. Toimiikohan tuo liikennemerkkitunnistin Suomessa 2012 mallin W212:ssa?
Tämä on mielenkiintoista, koska esim. W213:n julkistuksen yhteydessä uutisoitiin, että liikennemerkkitunnistin ei toimi, koska se hyödyntää myös karttaa, eikä Suomen kartta-aineistossa ole tarpeeksi tietoa nopeusrajoituksista. Lisäsyynä mainittiin kesä/talvinopeusrajoitukset.Hybridi kirjoitti:En osaa sanoa varmasti toimiiko 2012 mallissa, mutta 2014 ja 2015 mallien autoissa on ainakin tunnistin toiminut moitteettomasti.tj86430 kirjoitti:Ei ilman temppuja.terasankka kirjoitti:Nostan tälläisen vanhemman viestin, kun en löytänyt haulla vastausta. Toimiikohan tuo liikennemerkkitunnistin Suomessa 2012 mallin W212:ssa?
Olettaen että tuo uutinen on p...aa, ja uudemmissa tunnistin toimii, niin tästähän voisi optimisti ajatella, että jos autoon saa riittävän tuoreet softat ja kartat, niin vanhemmissakin pitäisi saada toimimaan. Kaikki rautahan autossa täytyy olla jo valmiina, jos varustekoodi 513 on ruksattuna ja se toimii muissa maissa.
- terasankka
Onko tietoa Mitäs kaikkien softien päivittäminen uusimpiin maksaa marmoritiskiltä?
En tiedä, mutta korostaisin, että tuo äskeinen oli pelkkää spekulointia, enkä tiedä saako vanhempiin millään päivityksillä tuota toimimaan (pl. siis tässä threadissä kuvatut "temput"). Mielelläni tietysti kuulisin asiasta jos joku tietää, haluaisin minäkin tuon toimimaan myös omassa autossa myös Suomessa.terasankka kirjoitti:Onko tietoa Mitäs kaikkien softien päivittäminen uusimpiin maksaa marmoritiskiltä?
Tässä nykyisessä menopelissä, joka käyttöönotettu loppuvuodesta 2014 liikennemerkkinäyttö toimii. Liikennemerkkitiedot tulevat sekä mittariston näyttöön että navigaattoriin. Auton olen hakenut pari kuukautta sitten Saksasta mutta tuskin siinä nyt eroa pitäisi olla Suomesta ostettuun verrattuna. Ja muistelen että edelllisessäkin toimi , joka käyttönotettu 2/2014. Molemmissa autoissa on comandin navisysteemit + tv ym.tj86430 kirjoitti:Tämä on mielenkiintoista, koska esim. W213:n julkistuksen yhteydessä uutisoitiin, että liikennemerkkitunnistin ei toimi, koska se hyödyntää myös karttaa, eikä Suomen kartta-aineistossa ole tarpeeksi tietoa nopeusrajoituksista. Lisäsyynä mainittiin kesä/talvinopeusrajoitukset.Hybridi kirjoitti:En osaa sanoa varmasti toimiiko 2012 mallissa, mutta 2014 ja 2015 mallien autoissa on ainakin tunnistin toiminut moitteettomasti.tj86430 kirjoitti:Ei ilman temppuja.terasankka kirjoitti:Nostan tälläisen vanhemman viestin, kun en löytänyt haulla vastausta. Toimiikohan tuo liikennemerkkitunnistin Suomessa 2012 mallin W212:ssa?
Tuskin alkaa millään softa päivityksellä toimimaan. En muista oliko tämä ketju vai joku muu niin joku taisi mainita että ei niillä ole vanhaa softaa intoa parantaa niin että ominaisuuksia tulee lisää. Osta uusi malli niin toimii, rahat pois periaatteella. Kyselin tuota W204 faceliftiin Saksasta asti mutta eivät vaivautuneet edes vastaamaan. Veholla vastaus oli että ei voi toimia Suomessa koska 60 ja 80 ovat niin lähellä toisia niin siksi ei toimisi. Sekin on täyttä paskaa. Syy on nuo karttapohjat, että sieltä puuttuu nopeustiedot. Laittakaa Can filtteri (SLA-moduli) niin johan toimii pelkällä kameralla. Eikä tule virheitä oli sitten kyseessä 60 tai 80 rajoitus.
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
Ex: Basuuna PWD -03
EX: Basuuna PWD -02
EX: W638 110D -97
