I have a trouble with my super turboed 603.961. Im using the manual getrag tranny, but I have big problems with slippering clutch. I have tryed a modified std flywheel with the sprinter plate and disc.
In the beginning of the summer it worked wery well, but it started to slip at the end of summer.
So now I wonder what clutch/plate you guys are using in yours super turboed 603.96x? I have plans for the "707" plate with a sinterdisc. It would hold up to 800nm.
Clutches - Superturbos. What are useable?
- Forced_Induction
- Viesti:
I'm interested in more info about your sprinter clutch.
How much power are you putting through it?
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
- Forced_Induction
- Viesti:
We really would like to know what clutch options are available.
1982 300D
Re: Clutches - Superturbos. What are useable?
I'd like to know what clutch and cover to use on a w211 e220cdi 646 engine with 6 speed manual. Would very much appreciate the help.
