For Sale: Big brake upgrade kits for 124, 129, 201
Lähetetty: Ma 21.04.2008 16:12
Upgrade Kit #1: SOLD
This is a set of four brake calipers from an early 500E. They are remanufactured by TRW and have never been installed. New brake pads and wear sensors are included. These are iron Ate calipers. The front size is 300mm x 28mm, the rear size is 278mm x 24mm.
These will bolt on to any 124 or 201 chassis, all years, all models. The only modification required will be trimming the rear dust shield, and this is only needed if your stock rear rotors are smaller than 278mm (i.e., most 201's, and most diesel or M103 124's). This is a perfect brake upgrade for the 124 or 201, and does NOT have clearance problems with the front ball joint like the smaller (294mm or 295mm) E320/E420/400E brakes do! You will need 16-inch wheels to clear the front calipers. Sorry, I do not have rotors available for this kit, but I can supply the part numbers you need to order.
Upgrade Kit #2: SOLD
I have a different brake upgrade kit for sale also (see photo below), with the same front calipers (but used, not new, and with used pads), new/rebuilt 278mm x 9mm rear calipers & pads (from SL500, not 500E), and new 278x9 rear rotors (but no front rotors). Since 124 wagons (and M104-powered 124 sedans) already have 278x9 rear rotors, this is only an "upgrade" for the W201, and diesel/M103 W124's.
Upgrade Kit #3: SOLD
This is a Brembo big brake kit for you serious horsepower junkies - click this link for full details and photos.
I accept PayPal for payments.. please email me if you have any questions!
