Pilot, Portugese, Ingenieur, Aquachronograph Da Vinci and Portofino are 6 legend types of IWC supplied that its birth. on the
time of 140th anniversary. IWC Schaffhausen launches the vantage of those 6 watches, reshowing the charms of those aged
collections. each and every edition of those 6 timepieces all include the genuine factors of each and every IWC look at
nowadays.
Pilot hand-wound
As the 1st specific look at for that even now young, gruelling type of transport it previously experienced practically every
one of the vital skillstiffany & co on board. the present interpretation of the mom of all IWC pilot's timepieces has the dial inside the
original, multiplied in sizing to that inside the 44 mm case, merely a tiny seconds hand collectively with a bidirectional
adjustable rotating ring using the luminous triangle fitted using the inside. This vintage is with 98300 calibre hand-wound
pocket look at movement. huge screw balance, Breguet stability spring. Nickel-plated and decorative three quarter plate
designed from nickel silver as well as the elongated index for simpler reliability adjustment inside the energetic period
inside the stability spring, Sapphire crystal glass, and see-through back again cover.
Portugese hand-wound
In 1939, since the 1st "wtiffany 1837ristwatch" it founded the huge sizing used near to the wrist that is really well-known today. it
absolutely was also the 1st to break the taboo of placing on a complete pocket-watch movements on one's arm. The situation
(44 mm) with its fluted bezel and slightly pulled reducing strap lugs is in preserving using the original. The Vintage
Portuguese does differ using the genuine in that it has antireflective, crossed out sapphire decanter or glass greater
compared to dial. It is powered over the 98295-calibre that is practically identical for that Vintage Pilot's look at
movement: hand-wound, huge screwtiffany and co balance, Breguet stability spring, nickel-plated silver three-quarter plate, pearled bridges
decorated with Geneva stripes.
Ingenieur automatic
The Ingenieur automated of 1955: No look at has defined the "technical" profile of IWC really such as the Ingenieur, which
was released in 1955 and which was the 1st look at to attribute the IWC automated movements designed by Albert Pellaton. With
its pawl-winding method as well as the spring-mounted rotor, it has remained a benchmark for look at engineering on the
greatest level - even although retaining the ultimate level of toughness.
This programmatic watch, tiffany braceletswhich exemplifies the look at making engineering inside the Schaffhausen manufacturer, introduced
IWC to the present era. An icon of the level of quality consciousness handed reducing supplied that 1868; it has remained
using the merchandise broad variety below numerous guises.
In 1989, a legendary model, the Ingenieur 500,000 A/m, founded a planet report with its antimagnetic factors for that
resistance of the mechanised look at versus one of the most severe magnetic fields.
Half a century best suited after its 1st appearance, IWC's watchmaking icon was fundamentally revised. That which much
greater than fifty many years ago ensured toughness and reliability using the Ingenieur - 1st since the 8531 and after since
the 8541 calibre - these times finds its logical evolution using the IWC-manufactured 80110 and 80111 calibre. The Ingenieur
automated is equipped with thistiffany jewelry unit, which also drives the "new" Ingenieur, introduced in 2005.
The vintage look at skills a 42.5-millimetre situation and between one of the most trendy Ingenieur dials - using the point-
stroke indices (the luminescent materials types the point) as well as the dauphine-style hands. This product is these times a
collector's rarity inside the really greatest order. the present homage to this look at monument dispenses using the gentle
metal situation inside the original, so affording an insight to the IWC-manufactured movement. using the antireflective,
crossed out sapphire decanter or glass greater compared to dial as well as the screw-in crown, the Vintage Ingenieur is
water-resistant to twelve bar.
IWC Schaffhausen
- gulfstream
Re: IWC Schaffhausen
IWC oli taannoin varsin kunnianhimoinen kellonvalmistaja.
Ei tuota Patek Philippeä ja Jaeger-LeCoultreakaan silti pidä väheksymän.
