Torque converter stall speed
Mercedes-Benz conversations only
Forced_Induction
Viesti Kirjoittaja Forced_Induction »
Will a 2100rpm converter from a later 722.3xx model fit a 722.315 and OM617
1600rpm is much too low to get my turbo spooled at low speeds without surge.
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
