Mersujen perävälitykset, tyyppi- ja varustekoodit, jne
jari k
Re: Mersujen perävälitykset, tyyppi- ja varustekoodit, jne
Viesti Kirjoittaja jari k »
arska10 kirjoitti:
jari k kirjoitti:Pitäs saada varustekoodit W212 kun ei toimi minulla ne kokeilemani linkit. WDD2120021A582942
Kiitos jo etukäteen :)
Tossa
Datacard
Identification number: WDD2120021A582942 2
Chassis
Sales designation: E 220 CDI
Order number: 0 1 227 12489
Delivery date: 21 12 2011
Paint code 1: 230U INDIGOLITE BLUE METALLIC FINISH
Equipment: 108A IMITATION LEATHER - GRAY
Engine no.: 651924 30 934995
Transmission: 722908 03 837389
SA code
052 AEJ 11/2
064 STEUERCODE MAGNETVENTIL M651
088 STEUERCODE 330 X 32 - BREMSE BEI 18 ZOLL BEREIFUNG
100A IMITATION LEATHER
108 CONTROL CODE MARKETING
1U2 SNOW GRID
202B OWNERS MANUAL AND SERVICE RECORD - GERMAN
218 REAR-VIEW CAMERA
229L GERMANY
22N STEUERCODE WERK SINDELFINGEN/GRAZ
230 PARKING GUIDANCE
240 LED DAYTIME RUNNING LIGHTS
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
255B MB MOBILO WITH DSB AND GGD
260B AIRBAGLABEL - GERMAN/ENGLISH
279 ELECTRONIC GEAR RANGE SELECTION
287 THROUGH-LOADING FEATURE
291 PELVIS AIRBAG (PELVISBAG)
294 KNEE AIRBAG
2U1 RADIATOR SHUTTER
2XXL FEDERAL REPUBLIC OF GERMANY
302B HEAD UNIT LANGUAGE - GERMAN
332B INSTRUMENT CLUSTER/HU LANGUAGE - GERMAN
386 UNIVERSAL TELEPHONY PACKAGE
427 AUTOMATIC TRANSMISSION 7-SPEED
428 STEER.WHEEL GEARSHIFT BUTTONS/SHIFT PADDLE PAINTED
474 DIESEL PARTICULATE FILTER
477 TIRE PRESSURE LOSS WARNER
485 (COMFORT RUNNING GEAR)
527 COMAND DVD APS WITH NAVIGATION
550 TRAILER COUPLING
580 AIR CONDITIONER
58U ROOF INTERIOR TRIM GRAY FABRIC
734 TRIM PIECES - WOOD EUCALYPTUS
802
81P COMAND WITH NAVIGATION UPDATE
915 FUEL TANK WITH GREATER CAPACITY - VOLUME 2
928 EXHAUST GAS CLEANING WITH EURO 5 TECHNOLOGY
953 CLASSIC/STANDARD EQUIPMENT
967 COC PAPER EURO 5 TECH. W. REGISTRAT .CERT. PART 2
A20 DIRECT START
A21 SHIFT BY WIRE
A62 FE TORQUE CONVERTER HOUSING 19
A66 FE CONVERTER 19 MM
A86 T VALVE BODY ASSEMBLY WITH VGS 3
A89 REDUCED-FRICTION
B03 DIRECT START / ECO START/STOP FUNCTION
B09 REFRIGERANT COMPRESSOR WITH MAGNETIC COUPLING
F212 MODEL SERIES 212
FW LIMOUSINE
G908 TRANSMISSION CODE VERSION 08
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
J1A NAT2 WITH OPTIMIZED DSM
J82 FULL-LOAD VENTILATION OM668
K11 ADAPTIVE STOP LIGHT FLASHING
K13 CONTROL CODE FOR SERVICE INTERVAL 25000 KM
K22 SOFTWARE CONTROL F. LOW BEAMS WITHOUT NIGHT DESIGN
L LEFT-HAND STEERING
M22 DISPLACEMENT 2.2 LITER
M651 R4-DIESEL ENGINE M651
P00 FLEET PACKAGE WITH NAVIGATION
R01 SUMMER TIRES
R12 16" LIGHT ALLOY WHEEL 9-SPOKE DESIGN ALL-ROUND
U01 REAR BELT STATUS INDICATION
U41 FUEL - WATER SEPARATOR AND LUBRICATION PACKAGE
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V14 SPEED- + LOADINDEX 92W
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
Kiitos :)
300cd
Viesti Kirjoittaja 300cd »
WDB46033317033032
Hei löytyisikö tuolla mitään tietoa autosta. En ole itse löytänyt sellaista dekooderia jolla löytyis oikeaa tietoa.
Kiitos
Diesel, ainut vaihtoehto
W460 300GD pätkä
W460 300GD pitkä
Ex
W460 300GD pitkä
W463 300GD pätkä
W124 200D
C123 300CDT
C123 300CD
S123 300TD
S210 E420
S210 290TD
W163 ML320
W201 190E 2.5-16V
W201 190D
W201 190D
W126 380SE
300cd kirjoitti:WDB46033317033032
Kiitos
Hei, kokeiles vaihtaa seiskan tilalle kakkonen, jos on automaatti?
arska10
Viesti Kirjoittaja arska10 »
Eikös tuossa pitäisi olla yksi kirjain välissä
300cd
Manuaali se on
W460 300GD pätkä
W460 300GD pitkä
Ex
W460 300GD pitkä
W463 300GD pätkä
W124 200D
C123 300CDT
C123 300CD
S123 300TD
S210 E420
S210 290TD
W163 ML320
W201 190E 2.5-16V
W201 190D
W201 190D
W126 380SE
arska10
Eikös tuossa numero 7 kohalla pitäisi olla kirjain
300cd
Tuossapa tuo
W460 300GD pätkä
W460 300GD pitkä
Ex
W460 300GD pitkä
W463 300GD pätkä
W124 200D
C123 300CDT
C123 300CD
S123 300TD
S210 E420
S210 290TD
W163 ML320
W201 190E 2.5-16V
W201 190D
W201 190D
W126 380SE
arska10
No onko se sitten varmasti wdb
Kiitos
Siis mikähän ongelma tässä oikein on, EPC tunnistaa tuon runkonumeron ihan tuollaisenaan.
Datacard
Identification number: WDB46033317033032 2
Chassis
Sales designation: 300GD284
Order number: 6 3 529 30351
Paint code 1: 5932 No code designation available
Engine no.: 617931 10 009516
Transmission: 717422 10 000214
Steering: 765502 10 003423
Cab: 460583 10
Transfer case: 750609 10 031790
Front axle 1: 730300 10 7031667
Rear axle 1: 741502 10 7532268
SA code
A70 DIFFERENTIAL LOCK, FRONT AXLE
A71 DIFFERENTIAL LOCK, REAR AXLE
C70 REAR TWO-PIECE BUMPER
F46 HEADLAMP WIPER/WASHER
G48 TRANSMISSION 5-SPEED GL 275
G75 SPEEDOMETER ADAPTER
H20 _______ - 20021122 - HEAT-ABSORBING GLASS
H20 _______ - 20120612 - HEAT-ABSORBING GLASS
H20 _______ - 20120604 - HEAT-INSULTING GLASS
H22 HEATED REAR WINDOW
H80 HEATER FOR NORDIC COUNTRIES
J33 CLOCK
N03 INTERMEDIATE TRANSMISSION WITH PTO
P85 No code designation available
Q58 TOW-OFF COUPLING, FRONT
S30 No code designation available
S32 No code designation available
V05 No code designation available
V18 INTERIOR TRIM IN BLACK
V34 _______ - 20120604 - GRAB HANDLE AND INSTRUMENT PANEL PADDED
V34 _______ - 20140407 - PADDED DASHBOARD
W83 No code designation available
Y10 _______ - 20130204 - FIRST AID BAG
Y10 _______ - 20120201 - FIRST-AID BAG
Z98 BILL OF MATERIALS ORDER
arska10
Nyt mullakin tunnisti tuon kun bootasin koneen :(
misi
Viesti Kirjoittaja misi »
Terves, saiskos joku tolla runkonumerolla jotain ulos, kun itellä mankeli paasaa vastaan, kun yritin ottaa selvää. WDD2122021A257630
Kiitos!
MB S212 220CDI -10
tj86430
Viesti Kirjoittaja tj86430 »
misi kirjoitti:Terves, saiskos joku tolla runkonumerolla jotain ulos, kun itellä mankeli paasaa vastaan, kun yritin ottaa selvää. WDD2122021A257630
Kiitos!
Kiovan poikain mukaan:
000A FABRIC
001A FABRIC - BLACK/ANTHRACITE
030 ELECTR. REGULATED DIESEL FUEL PUMP
040U BLACK
050 AEJ 19/2
061 STEUERCODE FUER KRAFTSTOFFPUMPE
22P TRACK PACKAGE
234 BLIND SPOT ASSISTANT
236 ADAPTIVE REAR INTERIOR LIGHT
255B No code designation available
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
294 KNEE AIRBAG
409 FRONT LEFT AND RIGHT MULTICONTOUR SEAT
423 5-SPEED AUTOMATIC TRANSMISSION
476 AUTOMATIC LANE RECOGNITION
518 UNIVERSAL COMMUNICATIONS INTERFACE (UCI)
525 CONNECT 20 HIGH (NTG7)
580 AIR CONDITIONER
690 EMERGENCY SPARE TIRE (MINI SPARE)
70O No code designation available
800 AEJ 09/1
875 HEATED SCREEN WASH SYSTEM
B12 WHEEL REPLACEMENT TOOL
FS COMBI - VEHICLE
G646 TRANSMISSION CODE VERSION 46
HA REAR AXLE
J54 JOINT FLANGE VARIANT
R01 SUMMER TIRES
R13 16" LIGHT ALLOY WHEEL 9-SPOKE DESIGN W/ WIDE TIRES
V72 SPEED- + LOADINDEX 99W XL
s213 220d -17
Villa Pikkujalo
misi
tj86430 kirjoitti:
Kiitos!
*varustelistaa*
Kiitos! Katos, tässä on 5-lovinen automaatti.
MB S212 220CDI -10
Tämä sivusto on jo kaksi kertaa muuttunut, ja aina hukassa kun muuttuu... eli tässä uusin versio, ainakin minulle:
Mercedes-Benz
Zulässige Rad- und Reifenkombinationen
https://www.mercedes-benz.de/passengerc ... odule.html" onclick="window.open(this.href);return false;
Tuolla tehtaan listaukset mihin mersuun sopii mitkäkin vanteet, tai siis olleet saatavilla tehtaalta.
1991 MB 190E projekti
300cd
Löytyiskö varustelistaa, wdb46033317010728? Itellä epc:ssä näkyi vain koodit, ei selityksiä.
Kiitos
W460 300GD pätkä
W460 300GD pitkä
Ex
W460 300GD pitkä
W463 300GD pätkä
W124 200D
C123 300CDT
C123 300CD
S123 300TD
S210 E420
S210 290TD
W163 ML320
W201 190E 2.5-16V
W201 190D
W201 190D
W126 380SE
tj86430
300cd kirjoitti:Löytyiskö varustelistaa, wdb46033317010728? Itellä epc:ssä näkyi vain koodit, ei selityksiä.
Kiitos
https://www.datamb.com/vin/v8y0XEGOZB8EN5Br6" onclick="window.open(this.href);return false;
s213 220d -17
Villa Pikkujalo
W210270
Viesti Kirjoittaja W210270 »
Osaako joku sanoa mikä välitys on autoni perässä
1997 vm w210 230 bensa
Laatikko 722.6
Perässä takakannessa numero r 124 351 30 08
Ja vetarit 100mm laipoilla
Vin numero WDB2100371A401849 jos se auttaa
jysi
Viesti Kirjoittaja jysi »
Takakannen numerosta ei ole apua, VIN:istä on. Alkuperäinen perä on A210 350 22 62 ja välitys 1:3,27
alottelevamersumies
Viesti Kirjoittaja alottelevamersumies »
voisiko joku opastaa miten tuo perän välitys oikeen selviää vin avulla
itsellä 1996 vm w202 c280 ja perä meni niin että rusahti
vin: WDB2020281F426696
arska10
Näyttäisi olevan 1:3.07 tuo välitys
Rise
Viesti Kirjoittaja Rise »
W 124 jenkkimallien perävälityksiä. Harvempia kuin euromalleissa, ainakin joissakin vuosimalleissa.
Mikäpä varuste voisi olla varustekoodi 431 vuosimallin 1986 250TD:ssä ?
Se ei ole "3-POINT SEAT BELT REAR CENTER" jonka esim. Lastvin tarjoaa.
Olisi mukava tietää, tuli sellainen rottelo ostettua ja muut 75% varusteista ovat mekaaninen antenni, sävylasit ja peräkontin suojaverho/verkko joista viimeksi mainittu kadonnut ajan saatossa.
tomant
Viesti Kirjoittaja tomant »
MBWorld.org löytyy eräs lista sivun https://mbworld.org/forums/mercedes-tec ... -list.html liitetiedostossa. Se viittaa pääntukiin ja turvavöihin takana.
tomant
Kas kiitos. Vaan onko sitten niin että alkupään mallissa olisi varustelistassakin mainittu pääntuet, kun kai ne kuitenkin kaikissa farkuissa on olleet aina.
Anzzu
Viesti Kirjoittaja Anzzu »
https://m.nettiauto.com/mercedes-benz/c ... 8&vifNav=Y mitkä off napit keskikonsolissa on?
WDB2032071F835883
Anzzu kirjoitti: Ti 20.06.2023 17:45 https://m.nettiauto.com/mercedes-benz/c ... 8&vifNav=Y mitkä off napit keskikonsolissa on?
WDB2032071F835883
No ESP off ja varashälyttimen sisätilavalvonnan ja hinaussuojan pois kytkennät.
Anzzu
DBFI kirjoitti: Ti 20.06.2023 19:49
WDB2032071F835883
ESP-off tajusinkin :mrgreen: , noita kahta muuta en ollut ennen nähnytkään, kiitos tiedosta!
Anzzu
Voisko joku tietävä katsoa sopiiko a1405403481 pts-johtosarja tähän koriin WDB2032081F778823, etupäähän siis
Sample
Viesti Kirjoittaja Sample »
Voisiko joku katsoa auton varustetiedot runkonumerolle WDB1241251B170670? Kokeilemani linkit eivät toimineet auton varustetietojen haussa :( Kiitos jo etukäteen avusta!
