190E 6.0 AMG
190E 6.0 AMG
Voi liikkua ihan kivasti jos pitoa löytyy. 400+ hp
http://www.geocities.com/shvoldum/conversions/amg.html
Aijaa, pelittää tuo mulla ainaki...
No tuossa teksti ja kuvat:
Mercedes Benz 190E 6.0 AMG
AMG 190E 6.0 litre, about 400+ hp.
The garage went through it and took the motor down, there are now new bolts everywhere. The engine is told to be from a 560 series, single cam V8, but with upgraded pistons and reworked insides. The battery is mounted in the trunk because of the weight factor.
It is a genuine AMG from the factory throughout, and it certainly also look like it. There are some extra gauges under the radio (Probably the same as the ones in the 16-valved ones), and extra wood trim around the dash. It has full black leather interior with tough cowhide.
There's nothing mechanically from the 190 on it, driveshaft, rear diff, radiator, brakes etc are all bigger and better. Even the underhood padding is removed since there isn't any room with the huge motor. Also no room for a moving fan, it relys on three electric fans on the front since the radiator is twice as thick and the pulleys are too close. Also no serpentine belts, only vbelts.
This car is a socalled widebody, a name AMG used on their tuned Mercedes when they had widened the body, hence the name.
The car is a 1987 Mercedes Benz 190E 6.0 AMG and its asking price is (was?) 25.000$.
Mikäs... ...ihan asia vehje, mutta miksi maski on punainen
Tuo pilaa koko keulan ilmeen... ....kromattu maski siihen, niin sitten on bueno!
Edelliset mercedekset:
W 123 240 D -1984
W 107 450 SLC -1973
W 124 220CE -1992
w ??? 508 -1979
W170 230 SLK -1998
Tämänhetkiset ajoneuvot:
1983 Mercedes 300SD
2002 316 Mercedes Sprinter ála FRANKIA 7000 (mobilehome)
2001 986 Porsche Boxster S
KTM 690 Rally 2008
W 123 240 D -1984
W 107 450 SLC -1973
W 124 220CE -1992
w ??? 508 -1979
W170 230 SLK -1998
1983 Mercedes 300SD
KTM 690 Rally 2008
tais olla toi korinvärinen maski AMG:n tapana tuohon aikaan...
esim AMG Hammer : musta maski
mustassa se vielä toimii,muttei oikein punaisena...
Jii
S205 / C220D Bluetec
ex Jaguar XJ8
ex S210 / E320CDI
ex Chevy Pornstart :)
ex Volvo S80 T6 200kW pappamalli:)
ex S124 / 300 TDT
ex C124 / 300CE
ex W124 / 250D
ex Jaguar XJ8
ex S210 / E320CDI
ex S124 / 300 TDT
ex C124 / 300CE
ex W124 / 250D
Tuo värkki näyttää täsmälleen yhtä hölmölle kuin telalla maalaamani Morris marina
. Yleisilme on sellainen kuin joku ei olisi viitsinyt purkaa autoa ennen maalausta
. Jos tuon tuollainen originaalina kuuluu olla niin valvotaan nyt sitten muutama yö, ei kait sitä parane mennä peukaloimaankaan
Ei miellytä minun silmääni, Brabus on parempi paja
