w211 E280cdi 06 aut.
W211E280
Viesti Kirjoittaja W211E280 »
Mikä voisi olla vikana?On tehoton,menee vikatilaan,vaihtaa miten sattuu.Toimii hienosti kun nyppään tuon ahtopaine/imuilma-anturin irti.On koitettu myös uudella osalla,eikä vaikutusta asiaan.
.Antaa vikakoodia:Motor Control:
ME - Motor/Engine Electronics (MB: 0034466740)
Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
Code: OBD00 P0107
Fault: No CAN message was received from control unit A1 (Instrument cluster).
Code: 002244
Event: Check component B28/5 (Pressure sensor downstream of air cleaner). 1
Open circuit in wiring / Short circuit to positive 2 Open circuit in wiring / Short circuit
to ground 4 CAN signal faulty 8 The atmospheric pressure between component
B28/5 (Pressure sensor downstream of air cleaner) and component N3/9 (CDI
control unit) is implausible. / Fault: Intake air temperature sensor 1 has a short
circuit to ground. Intake air temperature sensor 1 (cylinder bank 1) has a short circuit
to ground. / Fault: Y58/4 (Activated charcoal canister shut-off valve) (P0446, P0447,
P0448)
Code: 002025
