MB-klubin EPC/WIS-portaali muuttuu
jani_k
Viesti Kirjoittaja jani_k »
Kävin jotain varaosa-asioita katselemassa tässä eilen ja huomasin tämmöisen tekstin MB-klubin kautta olevassa EPC-portaalissa:
Most of you may be familiar with the Electronic Parts Catalogue (EPC for short), which is freely accessible to members of the officially recognised Mercedes-Benz brand clubs via our ClubLounge.
Daimler AG has decided to replace the EPC with the all-new XENTRY Portal for institutional users (branches, dealers, etc.) to ensure a streamlined, up-to-date offering for various different user groups around the world as we move forward. For individuals and other users the SAI-Portal was launched, including the ISP Parts Information as all new application replacing the EPC.
Following the successful launch of the XENTRY Portal during the course of the year, technical support for the predecessor EPC system can now no longer be maintained and the Electronic Parts Catalogue will be discontinued on 14.12.2018.
The EPC will therefore no longer be accessible via our ClubLounge starting 14.12.2018.
To ensure that you can access the new SAI-Portal for individuals in future, we are maintaining close contact with the respective specialist departments. Since the new system is subject to the latest legal regulations regarding data protection and security requirements, it is not possible to use the SAI-Portal via the ClubLounge without entering personal SAI-Portal registration and user login details as for the previous EPC offering.
This is why we are working hard on implementing personalised SAI-Portal registration for club members via our ClubLounge. The goal is to go online by the end of January 2019 with a corresponding SAI-Portal registration tool in the ClubLounge. All club members looking to use the SAI-Portal in future can sign up as users via the aforementioned registration tool. Personalised SAI-Portal access will be enabled starting in early February.
The process described will ensure that all system-side requirements for the SAI-Portal are met and is currently the only way of offering the required services to club members.
As such, you will not be able to access the new SAI-Portal and the ISP Parts Information when the EPC is taken out of service until after you have successfully completed the SAI-Portal registration procedure.
Following your SAI-Portal registration, however, the ISP Parts Information will be available to you around the clock with personalised access and you can push ahead your repair and restoration works for the 2019 classic car season.
Mikäli nyt en ihan ymmärrä väärin niin tämä tarkoittanee sitä että ollaan n. puolitoista kuukautta ilman varaosa/korjausoppaita kunnes saavat uuden järjestelmän taas pystyyn?
Re: MB-klubin EPC/WIS-portaali muuttuu
jani_k kirjoitti: Mikäli nyt en ihan ymmärrä väärin niin tämä tarkoittanee sitä että ollaan n. puolitoista kuukautta ilman varaosa/korjausoppaita kunnes saavat uuden järjestelmän taas pystyyn?
Siis ne jotka on klubin EPC:n varassa. Se puolitoista kuukautta taitaa olla aika optimistinen arvio.
Tuleehan klubin jäsenmaksusta palautus tuota ajalta?
Niin näkyi olevan. En itsekään usko, että 2 kk riittää järjestelmän ylösajoon. Viikolla tulee klubin tiedote aihesta meilitse jäsenille. En kyllä itse osannut edes ajatella jäsdnmaksun palautusta tuolta osin... Se ei kuitenkaan ole ry:ntuottama palvelu, vaan saamme sen emotehtaalta eikä sen ylläpito kuulu kerholle.
Toivon hartaasti, että kun systeemi saadaan ylös, se toimisi paremmin kuin piirimyyjien Xentryt nyt.
www.classicdata.fi
Timo L. kirjoitti:Niin näkyi olevan. En itsekään usko, että 2 kk riittää järjestelmän ylösajoon. Viikolla tulee klubin tiedote aihesta meilitse jäsenille. En kyllä itse osannut edes ajatella jäsdnmaksun palautusta tuolta osin... Se ei kuitenkaan ole ry:ntuottama palvelu, vaan saamme sen emotehtaalta eikä sen ylläpito kuulu kerholle.
On se klubin EPC/WIS kuitenkin monille 95% jäsenyyden "arvosta" ja tärkein syy liittyä jäseneksi. Jäseneksi liityttäessä palvelua myös markkinoidaan jäsenetuna. Klubilaisille ihan sama kuka sen palvelun tuottaa. Eipä tuolla itselle ole merkitystä eikä suuresta summastakaan ole kyse jos ei vuositolkulla mene uuden palvelun ylösajoon kuten korjaamopuolella.
esukki
Viesti Kirjoittaja esukki »
Täytin rekisteröintikaavakkeen 4.2, prosessin piti kestää 10...15pv. Nyt on kulunut jo 23pv eikä kuulu mitään.
Onko joku saanut vahvistuksen rekisteröinnin onnistumisesta?
-Esukki-
260 SE -87, R 320 CDI 4matic -06, A 160 BE -09, C200 A Kompressor -07, C180 TA -18
(ex. 190D -65, 200B -76, 230B -77, 190E 2.0 -86, V220 CDI A -01, C 180 TA Classic -01, E 230 TA Elegance -96, C 230 TA Avantgarde -08, C200 TA CDI Classic -08)
Ei voittoa täälläkään
Alimitoitettu varmasti tunnusten luonti, jos kymmenet tuhannet kerholaiset pistävät tunnuspyynnöt tulemaan...
www.classicdata.fi
Nyt toimii!
www.classicdata.fi
esukki
EPC toimii mutta WIS:iä ei enää löydy???
-Esukki-
esukki
Nonii, nyt se jo lakkasi toimimasta. Sisäänloggauksen jälkeen tulee virheilmoitus ja heittää ulos:
-Esukki-
tomant
Viesti Kirjoittaja tomant »
Juu ja sama kielellä en:
"Your account data is incomplete: There is no country assignment.
Please contact the relevant Mercedes-Benz market representative.
Thank you for your understanding."
tomant
Siis onko joillekin lähetetty uudet kirjautumistiedot vai mistä tietää että se rekisteröityminen on onnistunut? Itse laitoin kirjautumispyynnön päivää paria ennen kuin sen ilmoittautumisen piti alkaa (niin kertoi muutamat muutkin tehneensä) mutta mitään ei ole vielä tuosta uudesta varaosapalvelusta kuulunut.
Nippe
Viesti Kirjoittaja Nippe »
DBFI kirjoitti:Siis onko joillekin lähetetty uudet kirjautumistiedot vai mistä tietää että se rekisteröityminen on onnistunut? Itse laitoin kirjautumispyynnön päivää paria ennen kuin sen ilmoittautumisen piti alkaa (niin kertoi muutamat muutkin tehneensä) mutta mitään ei ole vielä tuosta uudesta varaosapalvelusta kuulunut.
Sähköpostiin tuli tunnukset ja linkki mistä pääsee kirjautumaan. Itsekkin laitoin silloin jo "liian aikaisin" sen hakemuksen ja tänään tuli tunnarit.
W206 C300e -22
(Seat Ibiza 1.0tsi -20)
Nippe kirjoitti: Sähköpostiin tuli tunnukset ja linkki mistä pääsee kirjautumaan. Itsekkin laitoin silloin jo "liian aikaisin" sen hakemuksen ja tänään tuli tunnarit.
Hyvä tietää. Parasta odotella vielä, taitaa mersulla olla vielä jonossa meitä ennen määräpäivää ilmoittautuneita, muut varmaan sitten pikapuolin siihen mennessä kun Notre Dame on taas kunnossa. Eipä itsellä mitään kiirettä tuon on-line palvelun kanssa olekaan, kunhan perään vastinetta klubin jäsenmaksulle.
Joo, mullakin herjasi äsken tuota maajuttua. Raakile se taisi olla SAI/Xentry kun tuli piirimyyjillekin...
www.classicdata.fi
jonteri
Viesti Kirjoittaja jonteri »
Tuli tunnukset, päästää siihenasti kun salasanan vaihto....ei hyväksy uutta salasanaa????
Vitollinen
Viesti Kirjoittaja Vitollinen »
Timo L. kirjoitti:Joo, mullakin herjasi äsken tuota maajuttua. Raakile se taisi olla SAI/Xentry kun tuli piirimyyjillekin...
Raakile se oli syksystä lähtien, ainakin täällä hämeessä. Muistan monta tuskailua varaosamyyjän etsiessä tarvittavaa komponenttia Vitooni.
Laitoin itse rekisteröinnin portaalissa alkuun n. viikon myöhemmin kuin vikkelimmät. Tänään tulivat tunnukset ja salasana sähköpostiin. Olen kuitenkin nyt reissussa, joten testailu jää myöhemmäksi.
Tuo EPC on ollut käytössäni iauton sivustolla, sitä Wissiä kuitenkin kaipaisin eniten. Wurthin ohjelmassa on rajallisesti joitain testaus- ja korjausohjeita, mutta ei läheskään riittävästi.
Vito veturina, kunnes ruoste meidät erottaa.
tomant
jonteri kirjoitti:Tuli tunnukset, päästää siihenasti kun salasanan vaihto....ei hyväksy uutta salasanaa????
Tuli tunnukset, antaa vaihtaa salasanan, päästää sivulle SAI Portal, Parts Information linkki antaa virheilmoituksen puuttuvasta maatiedosta, välillä heittää ulos, välillä ei. Xentry Portalissa teksti: "No service operation is assigned to the user."
Miten tämän pitäisi toimia?
tomant
jusi
Viesti Kirjoittaja jusi »
tomant kirjoitti:
tomant
Minulla ihan sama ongelma ja mietin ihan samaa. Korjaantuukohan itsekseen? Ja kuinka monta harrastajaa on jo ehtinyt lähettää Daimlerille asiasta palautetta :D (itse en lähettänyt).
esukki
Nyt se tuntuu taas toimivan...
-Esukki-
esukki kirjoitti:Nyt se tuntuu taas toimivan...
Näin tekee, mutta WIS:in puute harmittaa, tai sit en vaan osaa.
www.classicdata.fi
Tenutähti
Mistä WIS pitäisi tässä uudessa systeemissä löytyä? Jos toimisi? Vai onko se jätetty pois kokonaan?
Taitaa klubin jäsenyys loppua aika nopeaan jos wissiä ei ala löytymään! Osanumerot kyllä löytää kohtuudella muutenkin.
Eivät kai niin härskiä temppua kehtaa tehdä että ilman mitään ennakkoilmoittamista jätetään pois ylivoimaisesti tärkein syy maksaa klubin jäsenmaksua? Eiväthän?
Juu tiedän, ei ole klubin tuottamia palveluita epc ja wis! Mutta auliisti kuitenkin mainostavat jäsenyyteen kuuluvana etuna!
S211 320CDI -04
Vito 116CDI -13
Fiat 680H -79
PJ ja sihteeri selvittävät asiaa, harmittaa kyllä itseänikin kovasti tuo WIS:n puute.
www.classicdata.fi
Nippe
Kyselin itse myös tuota WIS:siä daimlerilta, tuli vastaus :thumbdown:
Eli ei ole tulossa.
W206 C300e -22
Onpa taas aivan hanurista tämäkin. Jokunen viikko sitten oli se tiedote, että ei vielä oikein tietojärjestelmä olekaan käyttökunnossa (vaikka piti olla), mutta jos maksat lisää, niin sitten yllättäen ei olekaan teknistä ongelmaa, joka estää käytön. Kuinkahan mahtaa olla, saako wissiä (tai jotain sen korviketta) jollain järkevällä lisämaksulla, vai onko se kokonaan deletoitu muilta kuin ammattikäyttäjiltä, joilla maksut eivät ole sillä tasolla, mitä harrastaja tavanomaisesti olisi läheskään valmis maksamaan?
Mitkähän mahtavat olla noi niiden ”legal reasons” käytännössä? Joku laki sattunut muuttumaan just samaan aikaan, kun keksivät vaihtaa järjestelmää ja muuttanut samalla korjausohjeiden jakamisen kirjautuneille ja jäsenyydestään maksaville käyttäjille lainvastaiseksi? Ja sama laki ei tietenkään koske räjäytyskuvien ja varaosanumeroiden jakamista samalle ryhmälle? Ehkä se on joku korjausohjelaki. :idea: Joojoo kyllä mä tiedän, että koko muutosta alun perin perusteltiin mm. jollain lainmukaisuusjutulla, mutta ei silti oma ymmärrys riitä. Vika lienee itsessäni tietenkin.
W124 250 D -92
C123 280 CE -81
W124 E 300 Turbodiesel -94
S211 E 220 CDI -09
Vitollinen
Nippe kirjoitti:Kyselin itse myös tuota WIS:siä daimlerilta, tuli vastaus :thumbdown:
[ [url=http://i398.photobucket.com/albums/pp69/Nippe-/Mobile%20Uploads/IMG_20190423_155753_zps9q936tvd.png] ][/url]
Eli ei ole tulossa.
Tätä minäkin osasin jo ounastella,eli WIS siirtyy maksumuurin taakse. Daimlerin aiemmassa viestinnässä hämäräksi jäi, sisältyikö siihen 50:n (+ alv.) /per year maksulliseen versioon todellakin kaikki. Lainaan tähän daimlerilta saamaani tiedotetta, sen varmaan muutkin saivat. Eli sen jossa kerrottiin rekisteröinnin viivästymisestä.
"Für eine Zugriffsberechtigung (pro User) auf die Teileinformation fällt lediglich eine Registrierungsgebühr an. Sie haben damit 1 Jahr lang uneingeschränkt Zugriff auf alle Ersatzteileinformationen von Mercedes-Benz Pkw, Mercedes-Benz Nfz, smart und Maybach."
"Osittaista tietoa koskevat käyttöoikeudet (käyttäjää kohden) veloitetaan vain yhdellä rekisteröintimaksulla. Tämä antaa sinulle vapaan pääsyn kaikkiin Mercedes-Benz-henkilöautojen, Mercedes-Benzin hyötyajoneuvojen, älykkäiden ja Maybachin osien tietoihin vuoden ajan." (Konekäännös saksasta)
Pitääkö tuo sitten paikkansa, vuosimaksulla saisi vapaan pääsyn kaikkiin...?
tomant
Vitollinen kirjoitti: "Für eine Zugriffsberechtigung (pro User) auf die Teileinformation fällt lediglich eine Registrierungsgebühr an. Sie haben damit 1 Jahr lang uneingeschränkt Zugriff auf alle Ersatzteileinformationen von Mercedes-Benz Pkw, Mercedes-Benz Nfz, smart und Maybach."
Tarkennus: Osittaista tietoa p.o. Osatietoa (Teileinformation), älykkäiden p.o. smartin (smart).
tomant
Nippe
Tästä jää käsitys, että on kyse vain varaosatiedoista. Siitähän siinä tiedotteessakin oli kyse, oli myös mainittuna Parts Information. WIS:sistä ja huolto-/korjausohjeista ei ole ollut missään mitään mainintaa, se on vain kaikessa hiljaisuudessa poistettu klubilaisilta. Ihan hanurista kyllä, WIS:sille on useikin tarvetta omissa jutuissa. :evil:
W206 C300e -22
Efraim
Viesti Kirjoittaja Efraim »
WIS:n poistumisesta kannattaa antaa palautetta MB-klubin paikaillisille jaospäälliköille. Tuota kanavaa käyttäen viestin mene pääkallon paikalle. Mä ainakin kerron palautteeni ja mainitsen että eropaperi on harkinnassa.
Viestiä on jo laitettu Etelä-Savon suunnalta toimistoa kohti. Laillisiksi seikoiksi voidaan käsittää myös amerikkalaisten oikeustaju mahdollisten vahinkojen sattuessa autoa korjatessa...
www.classicdata.fi
