Hi!
I'm helping a friend who owns a w123 300dt (OM617.950?) with manual transmission (4 speed). He is having a lot of trouble with clutch slipping. Even with original injection pump (just adjusted) the clutch wont hold.
The clutch is original 300d naturally aspirated. Is there any better clutch that fits right on the flywheel? He's got a Mynä modified pump just waiting to be mounted... And bigger turbo... And intercooler... So better grip on clutch is indeed needed.
Anyone who has a tip for us?
/ Kjell
Stronger clutch for OM617?
Kjell Niklasson
- Uusi tuttavuus
- Forced_Induction
- Viesti:
There is a seller on eBay that sells performance clutches. Follow to his website and you will find everything from OEM strength to all-out race clutches that work for our engines (Yes, a 240D clutch will work with a 300D).
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &rd=1&rd=1
How old and how many miles are on the clutch? I've had my 4-speed installed for over a year without any hint of slipping or chattering.
I'm not sure if the tranny can hold much more than 200HP or so. The automatics need some beefing up to hold the torque of these modified engines and I don't know of anyone that's beefed up an OM617 with a manual tranny behind it.
1982 300D
Maxed MW-Pump, Holset HE221W, straight pipe exhaust, A/W intercooler, W/M injection
W115 300D intake manifold, 2-Micron Baldwin BF7591-D fuel filter, W126 Gen-II front brakes
Webasto TSL-17 auxiliary hear, Battery relocated to the trunk, Factory skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Turbo Diesel
Kubota OC95, VZ21 turbocharger, Intercooler, Comet 40C/44D CVT
Kjell Niklasson
- Uusi tuttavuus
- Forced_Induction
- Viesti:
The stage 2 should be able to hold far more torque than the tranny could hold. Expensive, but pure Kevlar friction material would be worth it.
Spec Clutch Kit Stage 2 - Mercedes 240D 1968 - 1983 (2.4L) $440.68
http://optionimports.com/se252-819.html
Spec Clutch Kit Stage 2+ - Mercedes 240D 1968 - 1983 (2.4L) $495.88
http://optionimports.com/se253h-570.html
1982 300D
