Hello from Austria!
I was planning to help the 190D 2.0 from my grandfather to a little more horsepower ;o)
But I would not like to make too much smoke.
So I was thinking of an injection pump from a Mercedes Vito 2.3 Turbodiesel.
Do you know if this I.P. hast an boost pressure enrichment (ALDA) like common Mercedes turbo-diesel?
Thanks for help!
Does I.P. of Vito 2.3 Turbo hast LDA?
- Sisäänajossa
Re: Does I.P. of Vito 2.3 Turbo hast LDA?
Hi,
Yes it has, this picture is taken of the injection pump of Vito 2,3 TD. It should be "plug and play" installation.
http://www.nic.fi/~danes/w638_2/jutut/pic/p0241.jpg
...and the elemens have diameter of 6 mm, which means capability up to ~200 HP.
- Sisäänajossa
Thank you for the fast reply.veskola kirjoitti:Hi,
I think you already helped me with my 250D Turbo.
200HP
But is this really the ALDA the SAVUTUKSENESTO "ALASYÖTTÖ
The pump looks like the N/A I.P.
Actually i don't know what and how "ALDA" works/means, but in the pump of the picture (Vito/V-klassen) that SAVUTUKSENESTO "ALASYÖTTÖ" means the injection amount is restricted before boost pressure rises and that eliminate the pollution. The same issue can be found in any OM60x turbo engines of passenger cars . Boost pressure should be connected to that joint.
