Hi mate,
First of all, thanks very much for your respond.
I already visited a few mercedes forums but to be honest, when they find out that I´m trying to implant mercedes heart into other name brand vehicle they mostly stopped communicate. I bought a book about W124 but there is still lots of things missing. About oil coolers, tranny coolers and servo pump which I need to work it out as well. I would need some proper mercedes detail catalogue.
Sorry I´m responding with a little delay, but I had to translate my web pages for you and others interested in my project.
so check this out
http://www.spelius.com
sections J
eep-cedes, Jeep-cedes engine, Jeep-cedes T/TC spacer are already in english and ready for you
About coolers. My donor car has water cooler only. I´m not very sure about oil cooler and tranny cooler location. You wrote that front of left/right tyre. I have seen a few pictures, in stock it could be just next to the water cooler but it is upside down, so intake is going up and out from bottom... Am I right?
I have seen pictures as well and the car has two little coolers, one on each side and were located in corners of the front bumper. I´m not sure if it is stock or not???
I appologize for stupid question, but why downpipe has a different diameter than the rest of exhaust pipe? Can it be all 4" ?
Some of my mates told me, that behind turbo it does not really metter, just keep it easy flow, but I do not need to go from bigger diameter rearward to smaller diameter or do special curves. Is it true?
It do not have intercooler in stock. and it´s not easy to add intercooler while using stock turbo because of its possition. So changing turbo for a bigger one + doing custom exhaust manifolds + intercooler need to be done at the same time I think...
So I need a bigger pistons as well? May I ask you what brand or part number? I will definitely leave it for a while, but after I put all things back together I will definitely tune my engine up!
About swapping engine into a jeep. I did a few mistakes already. If I would do it again, I would definitely go for 3,9 Cummins like that:
http://www.dieselpowermag.com/features/ ... index.html
It has only 105hp but a huge amount of torque, easy to build in and all spacer are already manufactured and you just need to buy it.
Or Toyota Land Cruiser diesel....
Yes you are right, not as powerful as Mercedes but much easier to do it.
Engine does not run opposite direction but there is problem with oil pan. Is not located in the back of the engine as in jeep (front axle clearence) but in front. So you need to go backwards with whole engine-transmission-transfer case block towards cabine or go higer.
I made a decision to go higher and bought 6,5" rough country lift and I will try to work it out.
I am waiting for my spacer cover now, it should be done in a few weeks so we will see....
Here in Czech we cannot swap engines. If you swap diesel to diesel and petrol to petrol it´s always the way how to make it but you can not swap diesel to petrol or petrol to diesel.
You have petrol 4liter 1991 - should be the better HighOutput 242 one. It is the best engine what you can get. If a were you I would forgot to swap it. It is almost undestructable engine with the same strenght AW4 auto tranny and it works brilliant. If you need better MPG, go for LPG gas conversion. You can upgrade you engine as well from aftermarket parts, you have available stroking to 4,9 and supercharger as well.
The only cherokee´s weakness is diesel engine. The 2,1 Renault ("I am not going anywhere") or 2,5 italian VM shittt ("I am going but I am too fu*** slow") . I originaly have a diesel car. It is 3door rare version and I fall in love with it. So this is my reason for not selling it and buying 4.0liter HO
