MB C350e, W205 nykii matka-ajossa
Anadura
Viesti Kirjoittaja Anadura »
Terve
Alkoi 2016 vuosimalli C 350e Merssu nykimään. (ajettu 148 000). Tekee sitä joka vaihteella. Mikähän näistä koodeista mahtaa olla syy? Se on Veholla tonnit levällään, jos lähtee jokaista sitä kautta, sitä :shock: .
Car Scanner ELM OBD2
DTC report
Selected brand: Mercedes-Benz
VIN: WDD2052471F295886
============1==============
P0237
Raw code: 0237
ECU: Engine control unit
Status: Confirmed
OBDII: Turbocharger (TC) boost pressure sensor/supercharger (SC) boost pressure sensor A - low input
============2==============
P061A
Raw code: 061A
Status: Confirmed
OBDII: Engine control module (ECM), engine torque - performance problem
============3==============
P061B
Raw code: 061B
Status: Confirmed
OBDII: Engine control module (ECM), torque calculation - performance problem
============4==============
P061B(06)
Raw code: 061B06
ECU: Engine control unit[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
============5==============
P061A(27)
Raw code: 061A27
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
============6==============
P0237(11)
Raw code: 023711
============7==============
U0164(87)
Raw code: C16487
ECU: 7ED[Archive (inactive)]
OBDII: Data bus, AC control module - no communication
============8==============
U3017(00)
Raw code: F01700
ECU: 7EF
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
============9==============
U0146(87)
Raw code: C14687
Status: Test failed since last DTC clear
OBDII: Data bus, gateway A - no communication
============10==============
P1D03(13)
Raw code: 1D0313
Status: Test failed since last DTC clear, Test not completed during this operation cycle
============11==============
P052E(71)
Raw code: 052E71
Status: Pending, Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Positive crankcase ventilation (PCV) regulator valve - performance malfunction
============12==============
U0292(87)
Raw code: C29287
OBDII: Lost communication with drive motor control module B
============13==============
P13C5(23)
Raw code: 13C523
============14==============
P1670(85)
Raw code: 167085
OBDII: Electronic Feedback Signal Not Detected
============15==============
P06DA(00)
Raw code: 06DA00
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
OBDII: Engine oil pressure control - circuit open
============16==============
U0146(00)
Raw code: C14600
ECU: Transmission control unit[Archive (inactive)]
============17==============
P272A(00)
Raw code: 272A00
============18==============
U0168(87)
Raw code: C16887
OBDII: Data bus, alarm system control module - no communication
============19==============
P0D3B(00)
Raw code: 0D3B00
============20==============
P0CF6(00)
Raw code: 0CF600
Bomber4
Re: MB C350e, W205 nykii matka-ajossa
Viesti Kirjoittaja Bomber4 »
Lähtisin liikkeelle
P0237
Star
Anadura
Missähän kohtaa tuo mahtaa sijaita moottoritilassa?
amatoori
Viesti Kirjoittaja amatoori »
Käytäs piruuttas moottorin ohjausyksikön kaapelia irti ja tarkasta liitin silmämääräisesti ennenkuin alat antureita enempää tutkii.
TwiSt-
Viesti Kirjoittaja TwiSt- »
Hei,
Tuliko sulla auto kuntoon?
Itsellä 350E Hybrid 2015 151000km ajettu ja antaa koodit:
P1D0313 & P052E71 Kampikammion huohotusventtiilissä toimintahäiriö (tälle huolto tilattu jo mersulle).
P06DA00 Ilmeisesti öljypumpun solenoidiventtiili tai kaapeli vika?
B210F00 > ohjaintehostin virtapiiri 30?
U3017 BMS222PI (Akun hallintajärjestelmä) ?
P0CF4 OBL222 / OBL222_7KW (Lataus) ?
Osa noista löytyi sunki vikalistasta, tuliko kuntoon ja mikä oli vika?
--Elämässä täytyy olla jotain tähellistä--
Anadura
Ei ole vielä korjattu. Vaihdoin tuon turbon venttiilin (P0237) --> Ei mitään vaikutusta.
Tuota P06DA00 koodia sanoi korjaaja, että on solenoidin johto poikki jatkuvana vika ja ei auta nollauskaan. Öljypohja pitää irroittaa ja pakoputki edestä yms., että pääsee käsiksi.
Toinen koodi P1D0313 on kans kalliimpi korjattava sen työmäärän takia.
Tietäs vaan kumpi näistä aiheuttaa sen nykimisen niin aloittaisin siitä..
TwiSt-
Joo, 700€ on Hartikaisella korjaus osineen tolle P1D0313 & P052E71 ja selvittävät samalla lisäksi ton P1D0313 onko vika kaapelissa vai anturissa.
tahtoomersun
Eikö tuohonkin tonneja pala, jos osia arvaamalla vaihtelee? Marmorilla saattaisi tulla kerralla kuntoon ja joskus yllättävän pienellä panostuksella.
Perheessä:
W 243 EQB 250 -23
C 126 500 SEC-89
ex
S 203 C 200 CDI -05
S 205 C 220 CDI -15
S 204 C 350 CDI -09
S 212 200 CDI -11
W 208 CLK 320 -99
W 211 E 220 cdi -05
S 210 E 220 cdi -02
S 202 c 180 -99
Anadura
Huomenna liikkeeseen ihmettelemään nykimistä. Eiköhän se sieltä selviä.
tahtoomersun kirjoitti: Ti 14.06.2022 09:16 Eikö tuohonkin tonneja pala, jos osia arvaamalla vaihtelee? Marmorilla saattaisi tulla kerralla kuntoon ja joskus yllättävän pienellä panostuksella.
Anadura
Ei marmoriltakaan vikaa löytäneet.. Ohjelman laittoivat uusiksi. Eipä auttanut sekään.
TwiSt-
Tänään kävi auto huollossa. Huohotusventtiilin vaihtoivat se tuli kuntoon ja tuosta toisesta P06DA00 sanoivat että ei tarvi välittää.. Testerillä tutkivat ja se kertoo vaan että älä piittaa vikakoodista tyhjennä muistista, joten sille eivät ala tekeen muuta kuin toi nollaus.
mitr74
Viesti Kirjoittaja mitr74 »
TwiSt- kirjoitti: Ti 21.06.2022 17:01 Tänään kävi auto huollossa. Huohotusventtiilin vaihtoivat se tuli kuntoon ja tuosta toisesta P06DA00 sanoivat että ei tarvi välittää.. Testerillä tutkivat ja se kertoo vaan että älä piittaa vikakoodista tyhjennä muistista, joten sille eivät ala tekeen muuta kuin toi nollaus.
Muistatko mikä ton huohotusventtiilin vian syy oli? Siis mikä sen aiheuttaisi?
TwiSt-
mitr74 kirjoitti: To 13.06.2024 06:50
En valitettavasti muista mistä johtu.
