slk-98 huoltoilmaisimen nollaus KUINKA?
Olen tehnyt tarvittavan huollon mutta huoltoilmaisin näyttää´-190km kysymys kuuluu saanko itse nollattua sen vai onko mentävä merkkiliikkeeseen?kiitos
Toimisiko tämä:
http://wiki.answers.com/Q/How_do_you_re ... rcedes_slk
Hello, I just tried this out and it works for sure (November 2, 2006), it took me two tries so be patient. I have a 2000 SLK 230 so this should work for most model years.
There are two nobs on the instrument panel. The nob on the left resets your odometer, this is the nob we are going to use, lets call it button 1. In addition, there are two positions when you insert the key nto the ignition. The second position lights up all of the instrument lights before turning on the car, this is the position we are going to use, lets call it position 2.
1. Turn key in steering lock to position (2)
2. Within 4 seconds press button (1) twice
3. The present status for distance is displayed. Within 10 seconds turn key in steering lock to position 0 (starting position without taking the key out)
4. Press and hold button (1), while turning key in steering lock to position 2 again. The present status for distance is displayed once more. Continue to hold button (1)
5. Release button (1) when you hear a beep. You have now reset it successfully.
just tried on slk 2oo 2002 model worked first time thanks to the man that posted answer
Täytyy yrittääJarkkoN kirjoitti:Toimisiko tämä:
Kyllä saattaisi toimia:
http://wiki.answers.com/Q/How_do_you_re ... es_c_class
Turn the key to the accesory position, find the button on your instrument cluster on the left. push that button 2 times within four seconds of the key being on. turn the key off then back on and push that button and hold it. your maintenance lights will reset. i just did this on my 2000 slk 230. there are also how to videos on you tube. its very easy.
