My kompressor is switched OFF and bypass is opens when MAP more than 150kPa. Only turbo, only hardcoretomant kirjoitti: My settings for the kompressor are:
2. MAP less than 180kPa abs (freewheeling when MAP more than 180 kPa)
![Laughing :lol:](./images/smilies/icon_lol.gif)
Kompressor for dayli use only.
1. Tial .63AR turbine housingtomant kirjoitti: And setting for turbo is
1. Turbo wastegate 1.2 bar (gives 1.0 bar boost)
The turbo has a built-in bypass valve.
tomant
2. Tial 50mm blow-off
3. Tial 44mm v-band wastegate (Replacement 38mm) springs for 0.5bar (gives 0.5bar) and ECU boostcontroller (TPS, gear correction and external switch).
Night test on ~0.8-1.1bar(boost controller is not working properly):
![Kuva](https://lh3.googleusercontent.com/-4qx-JvRa9Gg/U-sYC20jyrI/AAAAAAAAC0I/U817BN9RecI/w911-h683-no/20140812_231254.jpg)
